Pneumatic cylinders
Edited by Mary C. Gannon
Pneumatic cylinders
Self-adjusting cushioning DSNU-PPS cylinders require no manual intervention to adjust end-position cushioning, even with friction and pressure changes. Combination of three different bearing caps and four end caps gives them four mounting options, including block-design end caps for direct mounting or with flange threads; end caps with threaded lugs and swivel bearings, with air supply connections that are lateral; or in-line with the cylinder axis.
Festo Corp.
(800) 993-3786
www.festo.com
