Edited By Mary C. Gannon
PDH position cylinder is available in 2.5 to 5 in. bores and rated to 3000 psi. All sensor components (except electrical connector) are imbedded internally within the cylinder for durability and long field life. Internal electronic feedback senses cylinder rod position and provides output (analog or digital) to allow constant monitoring of the cylinder rod position. Sensor voltage supply is 12 or 24 Vdc.
Cross Mfg., (620) 324-5525, www.crossmfg.com
