Double-acting 18D and 18SD heavy-duty air cylinders are available in both stud and universal mount with hard-coated anodized aluminum barrel.
Both have 1.12 in. bore and feature Nitrile seals rated for 180°F and 150 psi max. Cylinders feature chrome-plated stainless steel rods with brass pistons and have black oxide finished end caps. Designed with standard bumpers at both ends, they have low friction U-cup seals with moly lubrication.
Air Engineering and Supply
(800) 332-4181
http://bit.ly/hp1111AirEng
