Sleeve-actuated connectors
Edited By Mary C. Gannon
FasCal high pressure ball (HPB) series connectors are sleeve-actuated and provide fast, safe, and repeatable connections on 1/4 to 1/2 in. male NPT, -4 to -8 AN, and -4 to -8 compression threads, allowing users to simply calibrate numerous instruments in a short period of time. They are rated at 5000 psi and include a safety feature to prevent disconnect under pressure. Connection and release is simply done by pushing or pulling the sleeve onto and off of the fitting.
FasTest, (800) 444-2373, www.fastestinc.com
