Series 6000 quick disconnect couplings are interchangeable, according to ISO 7241-A. They are available in sizes from 1/4 to 1 1/4 in. and rated for pressures from 3000 to 5000 psi and working temperatures with standard seals –2° to 230°F. They feature a snap together locking system and poppet valve assembly. Internal valves are manufactured from hardened steel, standard seals are manufactured from Nitrile rubber; backup seals are manufactured from PTFE.
Pirtek USA, (321) 504-4422, www.pirtekusa.com
