Hydroven Oleodinamica cooling unit contains four components in one compact unit — oil tank, pressure controller, oil cooler, and filters. Two sizes — 8.5 and 13 — offer maximum flows from 40 to 130 lpm, pressures from 40 to 315 bar, and speeds to 2500 rpm. They have 8.5 or 13 kW heat dissipation. Oil tank capacity for both is 13 l and return line filtration is 25 m.
Muncie Power Products, (765) 2847721, www.munciepower.com
