Advertisement
NuLock Series rod lock product line is designed for safe, reliable load holding during emergency stop conditions when air supply drops in pressure. Piston-operated clamp mechanically locks a cylinder piston rod in place in the event of an air supply failure. Compatible with seven ISO/VDMA cylinder bore sizes from 32 to 125 mm and six NFPA cylinder bore sizes from 11/2 to 5 in.
Numatics Inc.
(248) 887-4111
www.numatics.com
