SE-200NYT is a compact and specialized bypass filtration system that is fitted with a pump and motor and processes 120 gal/hr. Maintains hydraulic systems to 1000 gal at more than 5 grades cleaner than new. Includes relief valve and pressure gauge. Uses Mseries element to remove all solid particles, water, and sludge. Three-stage filter element captures all contaminants in one pass without surface blinding.
Triple R America Co. Ltd.
(416) 413-9202
www.triple-rrr.com
