Truck, bus hose systems
Hose and connector systems meet or exceed SAE specifications for heavy-duty applications, especially truck engines subjected to high heat and high pressures. They are manufactured using True- Bore technology instead of standard 100R5 requirement to ensure exact specifications in matching hoses and couplings. Coupling and crimper products are also available to provide tight and leak-free, port-to-port connections.
Gates Corp., Worldwide Fluid Power Div., (800) 777-6363, www.gates.com/truck-bus
