PV360 variable-displacement, 360 cc/rev pump features a large servo piston for fast response. It operates at pressures to 5000 psi. Ripple chamber technology produces between 40-60% less pressure and flow pulsation than comparable pumps. Modular design, variety of compensator options (standard and remote pressure, load sensing, and hp limiting), and direct mounting of pilot valves allow easy in-field conversion. Metric and SAE mounting interfaces are available and ports can be ordered with metric or UNC/UNF threads. Parker Hannifin Corp.,
Hydraulic Pump Div.
(937) 644-3915
www.phpump.com
