MA 125 and 108R bent-axis motors are suitable for use in open- or closed-loop circuits, with displacements of 7.65in.3 (125 cc) and 6.61in.3 (108 cc), respectively. They accommodate continuous pressures to 5800 psi, 6525 psi peak, and rotational speeds to 8000 rpm, depending on models. Splined shafts and keyed shafts are available for all models. A variety of port configurations is available for interchangeability with most common models. Accessories include flushing valves and speed sensors.
Hydro Leduc N.A. Inc.
(281) 679-9654
http://bit.ly/HP611HydroLeduc
