Gear pumps
Edited By Catlin Nalley
High-pressure hydraulic gear pumps are constructed of cast iron and offer precise tolerance and reduced clearances. They have a maximum pressure range of 3000 psi (200 bar). Multiple mounting options are available and lip seals are standard. They have a temperature range of –40º to 225º F (–40º to 105º C). Displacement ranges from 0.008 to 25.0 in.3/rev (0.13 to 409.7 cm3/rev). Speeds range from 3600 to 1800 rpm depending on size.
Viking Pump, (319) 266-1741, http://bit.ly/HP711Viking
