Hot oil shuttle with relief valve fits into size 10 cavities. Springless valve is available with builtin relief setting of 100 to 400 psi and flow rating of 6 gpm at operating pressure of 5000 psi. Uni-body design and oversized seating allow high-torque tightening during installation, reducing need for locking mechanisms or lock wires. Internal pilots at port 1 or 2 allows flow to tank to remove oil from low pressure side for cooling or filtration. It is available with 3/8-in. BSPP or #6 SAE tank port.
Command Controls Corp., (847) 429-0700, www.commandcontrols.com
