IMH 8-mm cartridge-style shuttle valves solve hydraulic isolation problems in manifolds. Nondetented, selective design provides more than twice the flow (to 6 gpm) over 5.5-mm diameter model. Stainless steel body installs easily into a drilled hole, eliminating need for threads, o-rings, or inhouse designs. They are ideal as a signal for auxiliary functions, such as hydraulically released, springapplied brakes and load sensing applications.
The Lee Co.
(860) 399-6281
www.theleeco.com
