Flow diverter valves offer flows to 60 gpm and pressures to 5000 psi. Modular design allows up to five additional circuits with minimal pressure drop. Zinc-plated steel bodies and IP69-rated coils withstand severe conditions. They are available as 3- or 6-way single valves; creating up to 14-way flows is optional with modular diverters. Standard ports allow for electric, manual, or pilot pressure operation. Flow diverters can be positioned next to the control cylinders.
Bosch Rexroth Corp.
(610) 694-8298
www.boschrexroth-us.com/brh-m
