Ball valves FKB series medium-pressure ball valves provide a leak-tight seal up to 15,000 psig. Trunnion-style ball valve features directload design, for consistent sealing across a full range of pressures. Low-torque actuation eliminates need for assist methods and accessories in manual actuation. They feature a 0.209 in.-orifice, 316 stainlesssteel body construction, and reinforced PEEK seat seals and are rated for temperatures to 250°F. End connections sizes are 14, 38, and 12 in.
Swagelok Co.
(440) 649-5329
www.swagelok.com
