Manifold incorporates return filter head with filter check port, gauge ports for filter and working pressure, manual filter drain, common relief or unloading valve cavity, and auxiliary return port. Expands to accept DO3 single to three station or DO5 single station manifold. Return manifold for use in horizontal or vertical applications. O-ring seals manifold to its mating surface.
Hydro-Craft Inc.
(800) 566-1133
www.hydro-craft.com
