Rotary timing valve can sequence stations on index table
By Claire S. Goodwin, Scott Rotary Seals, Inc., Hinsdale, N.Y.
Using pneumatic cylinder-powered clamps to hold parts in place is a widespread practice, found in many automation sequences. When these sequences take place on a rotary index table, supplying and controlling compressed-air flow to a series of cylinders may become complex. (Manual clamping and unclamping is always an option - but they eliminate the desired automation of operation.) Add other pneumatic devices, and space limitations may prohibit the installation of conventional valving.
A rotating union and manifold can bring air to the rotary table but they only provide continuous flow. It still is necessary to control flow to the individual devices that are incorporated into the application.
Consider a simple, 6-position index table on which small parts are loaded into clamp fixtures. The clamps then close to hold the parts during subsequent operations that take place at the other index positions. Finally, of course, the part must be unclamped for removal at the unload position. If the clamp cylinders are single acting, six clamps would require six air connections through a 6-port rotating union to bring individual supply lines to each table station. Each port, in turn, still would need a method to turn on the air for clamping and exhaust it to unclamp. This adds six directional valves to accomplish the clamping sequence. Double-acting cylinders double the circuit complexity, calling for a dozen port connections, two at each station.
If, instead, a single rotary timing valve is installed, it can handle supply-air flow as well as control functions. This valve combines 360° rotation with a custom slotted element to provide automatic on/off control of pressure-fluid flow to individual clamping fixtures. (Should external control be required, it can be included within the valve.)
For example, if the load position must have a part clamped in the fixture prior to rotation, a single control can be used rather than the multiple controls required with a rotating-union arrangement. The predetermined sequence is machined into the rotary timing valve.
Part clamping is not the only application for rotary timing valves. They can provide complete control for multiple functions such as collet or chuck operation and spindle rotation, as well as actuation of cylinders, push rods for ejecting parts, air blast for cleaning, air motors, and pneumatic clutches and brakes. In fact, any function requiring on/off control during rotation can be accomplished easily and automatically with a rotary timing valve - replacing conventional methods like cams, solenoid valves, and switches. The valve simplifies control system design and piping arrangements. The cost reduction resulting from elimination of the system interlocks, usually needed for independent system-control elements, can be considerable.
Valve configurations may be cylindrical or disk type. Selection depends on the characteristics of the particular fluid, operating pressure, speed, and the physical requirements of the user's equipment. For attachment to an index table or other rotary machine element, the rotary timing valve can be built with a flange. Or it can be designed to mount on a through shaft or shaft end. Full 360º grooves can be included for continuous flow of other fluids, such as coolants, and for venting or barriers.
