Series 80 large orifice solenoid valves come with a manual override to open normally closed valves or close normally open valves without power. They come with ac or dc power, in port sizes from - to 3-in. NPT, with pressure ratings from 0 to 200 psi. Valve bodies are forged brass or 316 stainless steel. Seals of BUNA, FKM, EPDM, Neoprene, and Teflon are available. Entire range is available in forged brass; stainless-steel bodies have - (as direct lift type only), -, 1-, 1-, 2-in. NPT port sizes.
Peter Paul Electronics Co. Inc., (860) 229-4884, www.peterpaul.com
Circle 160
