Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 04 01 2008 79794 Proportion 00000052278
Proportional Flow-Control Valve
April 16, 2008
Normally closed two-way valve provides proportional flow control from direct, PFM, PNM, or PWM signal. It has 9 outlets, which can be controlled individually, in multiples of 3, or all 9. Each outlet can flow up to 180 Nl/min at 6 bar, ...
Normally closed two-way valve provides proportional flow control from direct, PFM, PNM, or PWM signal. It has 9 outlets, which can be controlled individually, in multiples of 3, or all 9. Each outlet can flow up to 180 Nl/min at 6 bar, with operating pressure from 2 to 8 bar. It accommodates non-lubricated dry air filtered to 40 μm. It is rated IP-62 and features an opening response time of <5 msec and closes in <5 msec, with a maximum frequency of 500 Hz.
Matrix Air Valves, (661) 299-2762
www.matrixairvalves.com
