Pneumatic manifold valve
VTUB-12 lightweight valve terminal is designed for localized machine mounted applications. It is capable of flows to 400 lpm and pressure to 8 bar. Lightweight engineered polymer protects against corrosion. Valve terminal is available as a multipin electrical connection for a clean and simple installation; as many as 35 valves can be installed on one terminal. Connection cables allow up to a 10 m separation between controller and valve, allowing valve terminal to be installed where it is needed.
Festo Corp.
(800) 993-3786
http://bit.ly/hp1211festo
