Air valves
Isonic MOD3+ Series air valves incorporates upgraded internal wiring, built-in PCB connector, and snap-on installation in a half-shell thermoplastic valve body. No additional wiring, connectors, or fittings needed to install valves. Design accommodates three-and four-way single and double solenoid valves, as well as direct-acting valves on the same manifold.
Mead Fluid Dynamics Inc.
(773) 685-6800
www.mead-usa.com
