High-pressure seals
Variseal seals use Turcon M30 polymer compound for high-cycle, high-frequency applications. Non-abrasive, high-pressure PTFE material offers low friction sealing, increased wear resistance, and leakage control. It securely seals throughout increased component life cycles. Unlike conventional elastomeric seals, it won't fail due to chemical attack, extreme heat or cold, extrusion, friction, or compression set.
Trelleborg Sealing Solutions, (260) 482 4050, www.tss.trelleborg.com
