Offline filters continuously filter hydraulic and gearbox oil with Radial Micro Filtration. A combined motor/pump unit draws the oil through the filter and pumps clean oil back into the system. The filters remove particles as small as 0.5 µm, reducing repairs and downtime. The units can work even when the main system is not in use. The filters are available with one, two, or four filter housings and in two lengths. For applications where electric power is unavailable, the systems are available with air-driven motors.
Stauff Corp., (201) 444-7800
