Pyplok mechanically attached connectors reduce assembly time by swaging it on a pipe or tube with a hydraulic handheld tool. Its three-step cold installation process is simple after cutting and deburring the tube or pipe.Features include: No skilled labor required; installation time measured in seconds; no welding; and no leaks.
The connectors are for use with ¼ to 2-in. OD tube, 6 to 90-mm metric tube, and ¼ to 3-in. NPS pipe. Pyplok is dependent on OD; the wall can be any thickness. The connectors handle pressures to 10,000 psi.
Tube-mac Industries Inc., (888) 285-9243
