FP-hp magnetic rotational-speed sensors, for use in hydraulic drives with pressures up to 275 bar, feature a 14.7-mm insert depth. The device’s heavy-duty brass housing keeps dirt and moisture out. The sensors operate over a 0.1 to 20,000-Hz range and guarantee high-EMC stability. The sensors also feature a measuring surface pressure resistant to 275 bar.
Rheintacho Messtechnik GmbH, +49 (0)761 45 13 0
