Cutting rings
DiNova cutting ring is used for hydraulic DIN 2352/ISO 8434-1 fittings for no leaking, clean equipment, and safe working conditions. Ranges from 6 to 42 mm OD, series L and S. Enables easy assembly of hydraulic pipe circuits. Metal/metal sealing reinforced by two PTFE seals and gripping safety. Seals won't go into compression position until crimping achieved. Compatible with 24° cone seal fittings.
Legris Inc., (480) 830-0216, www.legris.com
