Ergonomic VPFL air-powered vacuum lifter operates with a hoist for handling compact, heavy, non-and semi-porous loads in tight spaces. Frame needs 8 in. head room to lift and move loads up to 2000 lb. Features single-foam pad attachment, welded steel lifting frame, integrated vacuum guard system with check valves, gauge, and air filter. Functions with use of Venturi vacuum pumps.
Anver Corp., (800) 654-3500, www.anver.com
Advertisement
