Push-to-connect fittings
MB fittings are made of acetal resin polymer, making them stiff and corrosion and fatigue resistant. They provide high dimensional stability and enable quick, manual connection and disconnection. Inner O-ring and stainless-steel grip hold tight to pneumatic tubing. When tube is pushed to the bottom of fitting, stainless-steel collet grips it, allowing pressure on release ring to set tube free from fitting. They operate in pressures to 12 bar.
C.matic srl
+39 0362 805246
www.cmatic.it
